last person joined: 9 hours ago
Aruba AP 315 LED Status Power Green blinking
This thread has been viewed 59 times
  • 1.  Aruba AP 315 LED Status Power Green blinking
    Posted Mar 24, 2017 03:11 AM
    Hi Everyone
    Why Aruba AP 315 LED Status Power Green blinking
    Aruba Controller 7210 Version  6.5.0.4
    What causes. ?
  • 2.  RE: Aruba AP 315 LED Status Power Green blinking
    MVP EXPERT
    Posted Mar 24, 2017 04:53 AM
    Hey, if it is the power LED this would suggest the AP is booting? If there is problems with the AP booting, have you tried attaching a console cable and seeing if there is any issues with the AP booting?
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/21953/Default.aspx
    AP LED Guide
  • 3.  RE: Aruba AP 315 LED Status Power Green blinking
    Posted Oct 30, 2017 01:55 PM
    I had the same blinking power LED issue. Once I upgraded the ArubaOS to 6.5.4.3_61959 on the 7010 controller that the APs were pointing to, the blinking power LED became a steady green.
  • 4.  RE: Aruba AP 315 LED Status Power Green blinking
    Posted Apr 21, 2021 04:30 PM
    Excuse me, how did you update the software if the device doesn't load ... is it flashing green?
    Carlos Manuel Apaza Hurtado
  • 5.  RE: Aruba AP 315 LED Status Power Green blinking
    Posted Apr 21, 2021 04:31 PM
  • 6.  RE: Aruba AP 315 LED Status Power Green blinking
    Posted Dec 09, 2019 03:30 AM
    hope you are well, i have a question regarding my instant ON AP-11 , when i plugged on via power adaptor it continuously blinking green  and not flashes green and amber, kindly suggest me the possible solution at your earliest convenience.
    email: ali.hassan@ublfunds.com
    cell# 00923422131239
  • 7.  RE: Aruba AP 315 LED Status Power Green blinking
    Posted Dec 09, 2019 03:24 AM
  • 8.  RE: Aruba AP 315 LED Status Power Green blinking
    Posted Dec 09, 2019 03:26 AM
