We look after the network for a large oil & gas firm and support several sites spread across the UK. Over the past 6 weeks or so we have started to get issues with AP's stopping broadcasting and showing the 'r' for power restricted in the controller. Users can't access the AP but we can still see it online and talking to the controller, it just refuses to broadcast.
We've had several on our main campus site go into this mode and nothing we do to play with the power settings makes any difference. Sometimes they will just start working again for no obvious reason and others are still down right now. The switches power them show no issues and the units have been in place for 18 months without a problem. Cabling them directly into the switch doesn't help so it's not bad cabling in the buildings.
It has now spread to 2 other sites many miles away and we are still at a loss to explain it. If it is genuinely power then why do the switches show plenty in reserve and are running PoE phones and other systems without a problem? Why are they all going within a week or two of each other after many months of service? I have 2 Mobility Masters and 2 WLC's which were last updated in July to 8.7.x.x so in January I'm going to update them to 8.9.0.1 to see if that helps, but I doubt it. Anyone else seen this?
Kenny Mitchell
