  • 1.  Aruba AP-377
    Posted Aug 03, 2018 05:25 AM
    HI,
    I'm looking for the radiation patterns for the AP-377 which I'm struggling to find, are they available yet?
    Regards
    Stuart
  • 2.  RE: Aruba AP-377
    Posted Aug 03, 2018 10:14 AM
    The data sheet doesn't show the radiation patterns, but does provide this information:
    AP-377
    - 5 GHz 802.11ac 4x4 MU-MIMO (1,733 Mbps max rate) » Internal 80°H x 80°V Directional Antennas 6.3 dBi
    - 2.4 GHz 802.11n 2x2 MIMO (300 Mbps max rate) radios » Internal 80°H x 80°V Directional Antennas 6.4 dBi
  • 3.  RE: Aruba AP-377
    Posted Aug 09, 2018 10:01 AM
    Charlie,
    I was trying to find the image version of this, like the ones I have attached. Any ideas?
  • 4.  RE: Aruba AP-377
    Posted Aug 09, 2018 10:16 AM
    @stuart bunn wrote:
    Charlie,
    Understood. Unfortunately, I haven't seen plots published for the latest outdoor APs. I'm not sure why that changed, but will take this feedback back to the team.
  • 5.  RE: Aruba AP-377
    Posted Aug 09, 2018 10:20 AM
    Charlie,
    Thanks for your prompt response, this confirms why I couldn't find them.
    Much appreciated.
  • 6.  RE: Aruba AP-377
    Posted Aug 09, 2018 11:06 AM
    Stuart, attached are the plots for the AP-377.
  • 7.  RE: Aruba AP-377
    Posted Aug 09, 2018 11:14 AM
    Charlie,
    Wow nice find ! Just what I was looking for.
    Much appreciated.
  • 8.  RE: Aruba AP-377
    Posted Aug 09, 2018 05:03 PM
    @cclemmer I have also had similar trouble locating this info in the past.
    Can the entire library possibly be added to Aruba Support Portal under "Tools and Resources" page?
  • 9.  RE: Aruba AP-377
    Posted Aug 09, 2018 05:20 PM
    Good suggestion. I'll take that back to the product team as feedback.
  • 10.  RE: Aruba AP-377
    Posted Aug 28, 2019 11:45 AM
    Anyone know where there is such a big difference in coverage between the 377 (5GHz 6.3dBi gain/2.4GHz 5.4dBi gain) and 277 (higher gain antenna AP @ 6.5dBi) in Ekahau? Based on the antenna gain, the coverage for each AP should look close/similiar.
    The antenna patterns in Ekahau seem to match the Aruba documents for these AP models so I'm not sure why this is happening.
  • 11.  RE: Aruba AP-377
    Posted Sep 06, 2019 11:28 AM
    Thanks for the patterns, they gave me a good start for planning my project.
    I would only ask that you upload them at a higher resolution that 200x200?
    It would be nice to be able to actually see the gradient lines, and read the gradient numbers.
