This thread has been viewed 39 times
  • 1.  Aruba AP-515
    Posted Jun 16, 2021 11:59 AM
    Trying to configure Aruba AP-515 (rw) Unified AP . SSID not broadcasting on this . Tried reset and all no luck. Even setme up wireless not coming up
    sreejith soman
  • 2.  RE: Aruba AP-515
    Posted Jun 16, 2021 07:36 PM
    ok one possible cause could be that the AP is not getting enough PoE and hence it is disabling radios.
    are you powering it up from a 802.3at source?
    you can can console into it and check it out.
  • 3.  RE: Aruba AP-515
    Posted Jun 17, 2021 12:36 AM
    thank u , that was the problem. connected with power adapter,it started working.
    sreejith soman
  • 4.  RE: Aruba AP-515
    Posted Jun 17, 2021 02:01 AM
    Thats great.
