last person joined: 7 hours ago
Aruba AP-515 not broadcasting 5Ghz
This thread has been viewed 38 times
  • 1.  Aruba AP-515 not broadcasting 5Ghz
    Posted 30 days ago
    Hi
    I have an issue where a connected 5ghz devices keep connecting to 5g ssid but once a new device came to connect it cannot connect to 5hz network and only 2.4g is connecting. The only work around I found for this issue is to shut and restart the port from the network switch which restart the access point and I can connect new devices. Kindly help me with this issue.
    We use Aruba controller 7030 with version OS 8.10.0.8 LSR
    AP-515
    connected to cisco c2960x access switch
    Mustafa
  • 2.  RE: Aruba AP-515 not broadcasting 5Ghz
    Posted 30 days ago
    Hi Mustafa,
    first of all it is the decission by the Client to which band it is connected. Are those new Clients dual Band clients?
    Is Band Steering / Steering Mode enabled?
    Can you give an output of
    show ap bss-table ap-name <APNAME>
    show wlan virtual-ap <PROFILENAME>
  • 3.  RE: Aruba AP-515 not broadcasting 5Ghz
    Posted 24 days ago
    Hi Cordless,
    Sorry for the late reply I was out of office for couple of days. Here is what you requested :
    (WLC-ARUBA-TELEMTRY) [mynode] #show ap bss-table ap-name AP15-5038
    fm (forward mode): T-Tunnel, S-Split, D-Decrypt Tunnel, B-Bridge (s-standard, p-persistent, b-backup, a-always), n-anyspot
    cluster (cluster role): U-UAC, A-AAC, sU-Standby UAC, sA-Standby AAC
    Aruba AP BSS Table
    bss                ess                    port  ip           band/ht-mode/bandwidth  ch/EIRP/max-EIRP  type  cur-cl  ap name    in-t(s)  tot-t          mtu   acl-state  acl  fm  flags  cluster  datazone
    b0:1f:8c:89:2b:40  Telemetry              N/A   10.1.226.71  2.4GHz/HE/20MHz         11/7.0/25.2       ap    0       AP15-5038  0        47d:7h:3m:20s  1500  -          94   T   T               no
    b0:1f:8c:89:2b:52  Telemetry Guest        N/A   10.1.226.71  5GHz/HE/80MHz           157E/15.0/31.7    ap    0       AP15-5038  0        47d:7h:3m:20s  1500  -          94   T   T               no
    b0:1f:8c:89:2b:42  Telemetry Guest        N/A   10.1.226.71  2.4GHz/HE/20MHz         11/7.0/25.2       ap    1       AP15-5038  0        47d:7h:3m:20s  1500  -          94   T   T               no
    b0:1f:8c:89:2b:50  Telemetry              N/A   10.1.226.71  5GHz/HE/80MHz           157E/15.0/31.7    ap    0       AP15-5038  0        47d:7h:3m:20s  1500  -          94   T   T               no
    b0:1f:8c:89:2b:43  Fakeeh-Concent-Tablet  N/A   10.1.226.71  2.4GHz/HE/20MHz         11/7.0/25.2       ap    0       AP15-5038  0        47d:7h:3m:20s  1500  -          92   T   T               no
    b0:1f:8c:89:2b:51  Fakeeh Care            N/A   10.1.226.71  5GHz/HE/80MHz           157E/15.0/31.7    ap    0       AP15-5038  0        47d:7h:3m:20s  1500  -          99   T   T               no
    b0:1f:8c:89:2b:41  Fakeeh Care            N/A   10.1.226.71  2.4GHz/HE/20MHz         11/7.0/25.2       ap    0       AP15-5038  0        47d:7h:3m:20s  1500  -          99   T   T               no
    b0:1f:8c:89:2b:53  Fakeeh-Concent-Tablet  N/A   10.1.226.71  5GHz/HE/80MHz           157E/15.0/31.7    ap    0       AP15-5038  0        47d:7h:3m:20s  1500  -          92   T   T               no
    Channel followed by "*" indicates channel selected due to unsupported configured channel.
    "Spectrum" followed by "^" indicates Local Spectrum Override in effect.
    Num APs:8
    Num Associations:1
    Flags:       a = Airslice policy; A = Airslice app monitoring; c = MBO Cellular Data Capable BSS; d = Deferred Delete Pending; D = VLAN Discovered; E = Enhanced-open BSS without transition mode; I = Imminent VAP Down; K = 802.11K Enabled; m = Agile Multiband (MBO) BSS; M = WPA3-SAE mixed mode BSS; o = Enhanced-open transition mode open BSS; O = Enhanced-open BSS with transition mode; r = 802.11r Enabled; t = Broadcast TWT Enabled; T = Individual TWT Enabled; W = 802.11W Enabled; x = MBSSID Tx BSS; 3 = WPA3 BSS;
    The device I'm looking for is not connecting to this AP even though the device is setup to be connected only to 5hz and the in the same room. Actually the device is connecting to another AP far away.
    (WLC-ARUBA-TELEMTRY) [mynode] #show wlan virtual-ap Telemetry
    Virtual AP profile "Telemetry"
    Parameter                                          Value
    AAA Profile                                        Telemetry_aaa_prof
    802.11k Profile                                    default
    Hotspot 2.0 Profile                                default
    Virtual AP enable                                  Enabled
    VLAN                                               161
    Forward mode                                       tunnel
    SSID Profile                                       Telemetry_ssid_prof
    Allowed band                                       all
    Allowed 5G radio                                   all
    Allow 6GHz band                                    Disabled
    Disable 6GHz vap for mesh                          Disabled
    Band Steering                                      Enabled
    Cellular handoff assist                            Disabled
    Openflow Enable                                    Enabled
    Fine Timing Measurement (802.11mc) Responder Mode  Disabled
    Steering Mode                                      prefer-5ghz
    Dynamic Multicast Optimization (DMO)               Disabled
    Dynamic Multicast Optimization (DMO) Threshold     6
    Drop Broadcast and Multicast                       Disabled
    Convert Broadcast ARP requests to unicast          Enabled
    Authentication Failure Denylist Time               3600 sec
    Deny inter user traffic                            Disabled
    Deny time range                                    N/A
    DoS Prevention                                     Disabled
    HA Discovery on-association                        Enabled
    Mobile IP                                          Enabled
    Preserve Client VLAN                               Disabled
    Remote-AP Operation                                standard
    Station Denylisting                                Enabled
    Strict Compliance                                  Disabled
    VLAN Mobility                                      Enabled
    WAN Operation mode                                 always
    FDB Update on Assoc                                Disabled
    Pure UAC BSS Deferred Deletion Delay               10 min
    WMM Traffic Management Profile                     N/A
    Anyspot profile                                    N/A
    Below is an access point connecting thru 5g to the Telemetry device with ip 10.1.161.25
    (WLC-ARUBA-TELEMTRY) [mynode] #show ap bss-table ap-name AP15-5044
    Aruba AP BSS Table
    b0:1f:8c:85:e7:42  Telemetry Guest        N/A   10.1.226.70  2.4GHz/HE/20MHz         1/9.0/27.0        ap    1       AP15-5044  0        55d:23h:45m:0s  1500  -          94   T   T               no
    b0:1f:8c:85:e7:50  Telemetry              N/A   10.1.226.70  5GHz/HE/80MHz           36E/15.0/31.7     ap    1       AP15-5044  0        55d:23h:45m:0s  1500  -          94   T   T               no
    b0:1f:8c:85:e7:40  Telemetry              N/A   10.1.226.70  2.4GHz/HE/20MHz         1/9.0/27.0        ap    0       AP15-5044  0        55d:23h:45m:0s  1500  -          94   T   T               no
    b0:1f:8c:85:e7:52  Telemetry Guest        N/A   10.1.226.70  5GHz/HE/80MHz           36E/15.0/31.7     ap    0       AP15-5044  0        55d:23h:45m:0s  1500  -          94   T   T               no
    b0:1f:8c:85:e7:41  Fakeeh Care            N/A   10.1.226.70  2.4GHz/HE/20MHz         1/9.0/27.0        ap    0       AP15-5044  0        55d:23h:45m:0s  1500  -          99   T   T               no
    b0:1f:8c:85:e7:53  Fakeeh-Concent-Tablet  N/A   10.1.226.70  5GHz/HE/80MHz           36E/15.0/31.7     ap    0       AP15-5044  0        55d:23h:45m:0s  1500  -          92   T   T               no
    b0:1f:8c:85:e7:43  Fakeeh-Concent-Tablet  N/A   10.1.226.70  2.4GHz/HE/20MHz         1/9.0/27.0        ap    0       AP15-5044  0        55d:23h:45m:0s  1500  -          92   T   T               no
    b0:1f:8c:85:e7:51  Fakeeh Care            N/A   10.1.226.70  5GHz/HE/80MHz           36E/15.0/31.7     ap    0       AP15-5044  0        55d:23h:45m:0s  1500  -          99   T   T               no
    Num APs:8
    Num Associations:2
    Is there a possibility the issue from the OS ver ?
  • 4.  RE: Aruba AP-515 not broadcasting 5Ghz
    Posted 16 days ago
    any response please ?
  • 5.  RE: Aruba AP-515 not broadcasting 5Ghz
    Posted 16 days ago
    For more instant responses, please open a TAC case.
    I see channel 157E assigned, which may not be compatible with some devices. You may also have set a client limit per AP, but I believe minimum value is 32 clients per AP, which does not explain this on a close-to-empty AP. TAC may be able to check your logs and see what makes clients not connect.
    Upgrading to a recent firmware version in general doesn't hurt, but it's just a lucky shot. TAC may suggest to upgrade to a recent version as it fixes other thing and rules out a few things.
  • 6.  RE: Aruba AP-515 not broadcasting 5Ghz
    Posted 16 days ago
    Hi Herman,
    Thanks for your reply, I will review our options for upgrading as just recently upgraded to 8.10.0.0.8 LSR.
    and I see our only option now is to open TAC case.
    Appreciate your support.
  • 7.  RE: Aruba AP-515 not broadcasting 5Ghz
    Posted 29 days ago
    You might want to get that version of code up to 8.10.0.11LSR (mind the firewall opps as well); the reason is that there are a mass load of bug-fixes and kernel crash issues with 8.10.0.7LSR and 8.10.0.8LSR.  Check out the release notes; I think that I counted 16 bug fixes with that one model of AP alone.
  • 8.  RE: Aruba AP-515 not broadcasting 5Ghz
    Posted 24 days ago
    I will check the release notes thanks for the heads up. for the mean time we still facing this issue.
  • 9.  RE: Aruba AP-515 not broadcasting 5Ghz
    Posted 6 days ago
    Would be interesting to get the mgmt-frames output when the second device is trying to connect to the AP.
    #show ap remote debug mgmt-frames ap-name AP15-5044
    This will give us some more details whether the device tried to connect to 5 GHz but was denied by the AP
    Regards, Sajin
    ACMX, ACX-CA
  • 10.  RE: Aruba AP-515 not broadcasting 5Ghz
    Posted 6 hours ago
    Hi Sajinnair,
    I have opened a TAC support with Aruba and will start troublshooting this issue to find out the logs and solve this issue.
  • 11.  RE: Aruba AP-515 not broadcasting 5Ghz
    Posted 6 hours ago
    Sounds great - thank you for the update
    Regards, Sajin
    ACMX, ACX-CA
