Aruba AP on higher ceiling considerations
  • 1.  Aruba AP on higher ceiling considerations
    Posted May 10, 2017 01:16 PM
    Hi Forum,
    On a ceiling that is 30ft high, what are the considerations that I should keep in mind when placing AP? what difference should I think about from a conventional 10ft high?
  • 2.  RE: Aruba AP on higher ceiling considerations
    Posted May 10, 2017 02:52 PM
    What kind of space is it?  Open?  Are there walls?  High density?  There are many considerations.
  • 3.  RE: Aruba AP on higher ceiling considerations
    Posted May 10, 2017 02:54 PM
    Mixed office space of cubicles and conference rooms.
  • 4.  RE: Aruba AP on higher ceiling considerations
    Posted May 10, 2017 04:42 PM
    Generally speaking 30ft should be ok using the standard built-in antennas of the indoor campus APs.
    What's the horizontal) AP to AP spacing?
    As a general guideline, you may want to consider more directional antennas if the AP-AP spacing is less than the vertical AP height.
  • 5.  RE: Aruba AP on higher ceiling considerations
    Posted May 10, 2017 05:27 PM
    The horizontal AP spacing is 50ft center-to-center. So external antennas or the built in one are fine?!
  • 6.  RE: Aruba AP on higher ceiling considerations
    Posted May 11, 2017 12:42 AM
    I would not anticipate any issues using the built-in ones.
  • 7.  RE: Aruba AP on higher ceiling considerations
    Posted Aug 08, 2019 04:45 AM
    30 ft with normal AP is fine !!!  ...  please advice how can we can the max heights for an AP?
  • 8.  RE: Aruba AP on higher ceiling considerations
    Posted Aug 08, 2019 09:42 AM
    This is an old thread. You may want to post a new question with more details on what you need. It's not clear from this post. Thanks!
