Aruba AP use which Mode for regional office
  • 1.  Aruba AP use which Mode for regional office
    Posted Jul 15, 2018 10:15 PM
    My customer has 3 regioanl office (RO 1, 2, 3). All respective regional office has it own DHCP server for it end point device, but the Aruba controller was at HQ office. Connection between the HQ office and regional office is using IP-VPN. All 3 regional office will use IAP305, cause my customer want to centrally manage all the Aruba AP. My customer want the wireless end point device the get the IP address locally and not from the Aruba controller at HQ office. May I know which mode should I use is bridge and split tunnel mode? Please advise and give some guide. Now Aruba controller running AOS 6.5
  • 2.  RE: Aruba AP use which Mode for regional office
    MVP EXPERT
    Posted Jul 16, 2018 02:01 AM
    Are these Campus AP's or Remote AP's? If there is already a VPN between the two then I suspect you will not need to configure as Remote AP's. So if a Campus AP, either Bridge or Tunnel will be your forwarding selection depending on the requirements.
  • 3.  RE: Aruba AP use which Mode for regional office
    Posted Jul 16, 2018 02:43 AM
    My customer main objective as below:
    *  For all staff wireless end point device get the IP address locally from the regional office's DHCP server, is not       from HQ  office.
    *  my customer another requirement which is for Guest and mobile SSID get the DHCP IP from the Aruba
    *  All regional office's Aruba AP must be manageable by Aruba controller at HQ office.
    Can it be done as above requirement? Please advise.
    If configure IAP305 as Campus AP with bridge or tunnel, which one is better? What are the requirement and info are needed for both (bridge or tunnel)?
  • 4.  RE: Aruba AP use which Mode for regional office
    MVP EXPERT
    Posted Jul 16, 2018 04:25 AM
    All of your customer requirements can be achieved using a physical controller. You've mentioned an IAP, this does not use a physical controller. The terms tunnel, split tunnel and bridge are usually associated when using a physical controller. See below:
    https://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/VirtualAPs/Virtual_AP_Profiles.htm%3FTocPath%3DVirtual%20APs%7C_____2
    If you are looking at the Instant product line, requirements 1 and 2 will be met, as for requirement 3 you would need a centralized management solution such as AirWave or Aruba Central. If not each Aruba Instant site will be managed as a separate entity.
  • 5.  RE: Aruba AP use which Mode for regional office
    Posted Jul 16, 2018 04:32 AM
    My customer just bought IAP305 and conver it to campus AP to the Aruba controller.
  • 6.  RE: Aruba AP use which Mode for regional office
    MVP EXPERT
    Posted Jul 16, 2018 04:43 AM
    Perfect, so you can use the tunnel options. The link provided above identifies the options and their use cases.
  • 7.  RE: Aruba AP use which Mode for regional office
    Posted Jul 16, 2018 04:47 AM
    Ok. You mean use tunnel model as below requirement? No need use bridge mode?
    *  my customer another requirement which is for Guest and mobile SSID get the DHCP IP from the Aruba  controller at HQ office.
  • 8.  RE: Aruba AP use which Mode for regional office
    MVP EXPERT
    Posted Jul 16, 2018 04:50 AM
    For Staff you can use tunnel or bridge, as long as there is a DHCP server available in the local VLAN. For Guest, you would use tunnel mode as the Captive Portal traffic will need to be tunneled to the controller in order for the Captive Portal to be displayed.
  • 9.  RE: Aruba AP use which Mode for regional office
    Posted Jul 17, 2018 02:03 AM
    All 3 regional office was flat network and don't have VLAN because it is small branch office.
    As for Guest SSID, customer said they wan to use WPA2 instead of captive portal.
