Hi
Would like to know if there is any documentation on how many devices/clients can be support on Aruba AP 205 model.
Is there a table for all the AP models on how many devices/clients it can support ?
My customers have been asking me.
It really depends on your environment. There is no official, one size fits all answer other than the physical limitations of the AP which is 255 clients per radio.
Here is the AP matrix with specifications:
http://www.arubanetworks.com/pdf/products/MAT_AP.pdf
You should work with your Aruba account team or partner to determine the best APs for your environment.
Any performance report on 255 clients connection ?
thanks
Technically 255 clients can be associated to the AP.
If only 10% of the 255 clients concurrently transmitting will it be fine ?
