Aruba Ap205 low speed
  • 1.  Aruba Ap205 low speed
    Posted Mar 13, 2016 12:49 PM
    Hi All.
    I am faceing problem in my Ap 205 its giveing me 70 mbps speed and my link is 300 mbps if i replace my Ap its working fine buht this ap is give 70 mbps .what culd be the cusese and what is the solution
    Regards
    Waqar
  • 2.  RE: Aruba Ap205 low speed
    Posted Mar 13, 2016 01:23 PM
    Wireless is half duplex, so you should expect no more than half your link speed to start.
    If there are other people on the same access point, you can expect even lower speeds.
    If there is higher utilization or other access points on the same channel as your access point, you can expect even lower speed than that.
    If your client is on the 2.4ghz band, you can expect more interference and more slowdowns because more devices are on that band that cause contention.
