Aruba APs Park under All Routers
  • 1.  Aruba APs Park under All Routers
    Posted Mar 12, 2012 03:52 AM
    Just a check with you guys, why 2 of my APs was found under Monitoring > Networks > All Routers.
    Thanks..
    Info
    Controller - 650
    APs            - 105
  • 2.  RE: Aruba APs Park under All Routers
    Posted Mar 12, 2012 08:20 AM
    Which AOS version are you running?
  • 3.  RE: Aruba APs Park under All Routers
    Posted Mar 13, 2012 10:11 PM
    AOS ver 5.0.2.0
    Just to add on, I have 2 APs at Site A (HQ), 2 APs at Site B, 2 APs at Site C.
    only Site C APs was found under "All Routers". My controller was at Site A
  • 4.  RE: Aruba APs Park under All Routers
    Posted Mar 14, 2012 12:11 AM
    Routers are detected based on the TTL of received traffic on the wired side.
    The detection would be typically from a Broadcast/Multicast Packet (like DHCP)
    Typically, this would mean that there is a L3 AP.
    If this is a Valid AP (Aruba AP in this case), there should not be any concern;
    But if there are non-valid APs, this would mean that there is a L3 AP deployed;
    - If it is of a concern you would have to locate the AP (manually or using the location tracking functionality with ArubaOS) and see if this is a Un-authorized Device.
