Aruba auto backup tool
  • 1.  Aruba auto backup tool
    Posted Dec 14, 2015 05:47 AM
    I've set up the auto backup tool for CPPM and its quite happily downloading tips data from all the members of our cluster. The thing is, the backups are rather small. When I do a manual backup of each cluster node, we're talking of backups in the region of ~2Gigabytes as I save all the session info as well. I'm guessing that the backup tool only backs up the tips database and not any session info. Is this the case?
    Can you configure the backup tool to do this?
    A
  • 2.  RE: Aruba auto backup tool
    Posted Dec 14, 2015 05:50 AM
    Did you change the auto backup setting to Config/session in the cluster wide parameters?
  • 3.  RE: Aruba auto backup tool
    Posted Dec 14, 2015 05:55 AM
    Didn;t know there was one :-)) I'll go look
    A
  • 4.  RE: Aruba auto backup tool
    Posted Dec 14, 2015 06:00 AM
    There's nothing in the global section of any of the config files relating to backing up session info.
    Configs are what came with it other than pointing it at our master publisher.Docn seems to be a bit limited for this code.
    A
  • 5.  RE: Aruba auto backup tool
    Posted Dec 14, 2015 06:05 AM
