Hi Community, do you know if there is any tool in order to plan beacons that can work as RF-Planner in order to have an Idea on how many beacons the implementation needs to have ?
The following Validated Reference Design will help. Placing every 10 - 15 meters a beacon depending on the area you want to cover will result in accurate indoor location.
Aruba Beacons Validated Reference Design
