Location Services
last person joined: 9 days ago
Location-based mobile app development and Bluetooth-based asset tracking with Meridian. Gathering analytics and business intelligence from Wi-Fi with Analytics and Location Engine (ALE).
Aruba Beacons - Custom endpoint notifications
  • 1.  Aruba Beacons - Custom endpoint notifications
    Posted Jun 08, 2016 04:11 AM
    I'm tryint to do some test of Custom endpoint notifications with the Aruba Beacons and Meridian.
    When I press the test bottom to check the target URL (in this case http://httpbin.org/html) i get this -->
    Error: Uh oh - there was a problem triggering that endpoint. Status: 400 (Received bad status code 405 from url http://httpbin.org/html).
    I also tried with other URL (http://google.com), and i recived the same error.
    Could someone tell me whats wrong  and give me a URL that works to test a custom endpoint campaign?
    Thank you!
    #ALE
    #LocationServices
    #Meridian
  • 2.  RE: Aruba Beacons - Custom endpoint notifications
    Posted Jun 08, 2016 10:08 AM
    Ramon,
    The external trigger URL should receive and interprete the JSON data that Meridian sends to it. So you need some dedicated PHP script or web application there, instead of pointing it to an arbitrary web site.
    I created a short video around this question that shows the data coming in from the Meridian cloud and a web-app responding to that. This video is here: https://www.youtube.com/watch?v=DIF4SqyQkdI
    Hope that video answers your question.
    Example data coming in from Meridian (note it comes in in json format, not the format below):
        [is_enter] => true
        [campaign_id] => 5647648723828736
        [broadcaster_id] => 85BAEDEA-1ACE-404B-874D-29AC21C18D58:16005:17491
        [device_id] => 318e22ed-7450-39a6-bbad-c6eb19d3b79b:com.arubanetworks.campus
    And if I have an (OAUTH) authenticated request, it has an additional authentication_token:
        [is_enter] => true
        [access_token] => bf5268e4a9baa3835c5be135e4715073f93a559e
        [device_id] => 3da7cf8c-7cae-3b71-8a73-d2a078c67744:com.arubanetworks.campus
    The access_token can be used to lookup the user information (in my case my Name and e-mail) and use it on your server.
    Herman
  • 3.  RE: Aruba Beacons - Custom endpoint notifications
    Posted Jun 08, 2016 10:40 AM
    Thank you very much Herman!
    a very usefull video :)
    @Herman Robers wrote:
    Ramon,
        [is_enter] => true
        [is_enter] => true
    Herman
  • 4.  RE: Aruba Beacons - Custom endpoint notifications
    Posted Jun 08, 2016 12:11 PM
    We've found that http://requestb.in works pretty well for us as a testing custom endpoint.
    Cheers,
    Shawn
