Aruba Central access
  • 1.  Aruba Central access
    Posted Apr 19, 2017 03:18 PM
    Is there a way  to add more users the ability to access the Aruba Central for our stuff?
    Everything I've found in it looks llike I am the only user that can access it and I have no way to delegate more.
    BTW, navigating through HPE sites are impossible.
    Chuck
  • 2.  RE: Aruba Central access
    Posted Apr 19, 2017 03:41 PM
    Central has many level of abstractions and granular access levels. Are you in MSP mode or non MSP? Based on that an advise is possible.
    Thanks.
  • 3.  RE: Aruba Central access
    Posted Apr 19, 2017 04:30 PM
    At the moment I'm just starting the free trial to see what it's all about. I will have several facilities and I think this will probably work out for management. I just need to figure some things out.
    I can't be the only guy who can access it, I already have a lot to do ;-)
    Chuck
  • 4.  RE: Aruba Central access
    Posted Apr 19, 2017 05:09 PM
    For starters can you check here:
    http://help.central.arubanetworks.com/2.3.2/documentation/online_help/content/user%20guide_olh/maintenance/user_management_central.htm?Highlight=users
    This link tells you about various user levels and how to create additional users.
