Aruba Central account and IAP Activation key
  • 1.  Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 10:53 AM
    Got my Aruba Central account, very exciting.
    1. Doesn't discover my devices (which I expected)
    2. It says to log into my IAP cluster and goto Maintenance Tab and find the Cloud activation key
    This key does not seem to exist. I assume the devices are supposed to be registered somehow?
    My IAP is in activate but nowhere do I see a cloud activation key
    I'd like to add an IAP to this beautiful product.
  • 2.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 01:17 PM
    What version of IAP SW are you running? The minimum is v.6.2.1.0-3.3.0.3.   Here is a screen capture of my IAP running the recent v.3.4.
  • 3.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 02:15 PM
    I have the same question.  I'm running FW 6.2.1.0-3.4.0.1_39461 and don't see where to add my cloud key to the site so it's seen.
  • 4.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 02:18 PM
    Click the "Where are my devices" link and it will ask you to enter the keys manually.
  • 5.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 02:35 PM
    interesting.  Doesn't work in chrome, but I see it in IE 10.
    Any who, I add my cloud code and mac add of the VC in both : delimited and non delimited.  I get failed to add the device.
  • 6.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 03:09 PM
    Running 3.4.0.2
    I don't see it.
    I just found out the possible reason why I don't see it is because my RAP-109 are beta units and the serial number is only 3 digits.
    Logged into another one of my IAP clusters and I have the validation key.
  • 7.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 03:16 PM
    what mac address did you use to add it and how did you delimit it?
  • 8.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 03:42 PM
    i cant add the MAC i use 00:0b and without delimits, i use chrome and internet explorer
  • 9.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 04:24 PM
    Hi there
    We are noticing some sync issues in our backend that is causing this for some of our users. We are actively working on this. We expect that this should work in the next 2-3 hours.. I will send an update on this forum as soon as this is available.
    Rajeev
  • 10.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 05:21 PM
    Hello All,
    If you do not have the MAC address of your IAP handy, here is an easy way to pull this from the IAP UI.
    Step 1: Click on More -> Support
    Step 2: Pick a ‘Target AP’
    Step 3: Select Command ‘AP Datapath Bridge Table’
    Step 4: Pick the MAC address that has destination ‘Local’
    The MAC address along with the cloud activation key will enable you to add your device to Aruba Central
    Typically users will not have to manually add devices. We will populate the list of APs automatically based on the customers purchase history.
  • 11.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 05:24 PM
    'show ap ids radio' is a quicker method
    IAP-QC-MON-DVO01-WAP2# show ap ids radio
    Swarm Radio Whitelist
    Radio MAC Address  AP MAC Address
    6c:f3:7f:d1:36:30  6c:f3:7f:c5:13:62
    6c:f3:7f:d1:37:00  6c:f3:7f:c5:13:70
    6c:f3:7f:d1:36:20  6c:f3:7f:c5:13:62
    6c:f3:7f:d1:37:10  6c:f3:7f:c5:13:70
  • 12.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 05:43 PM
    Agreed. If you have CLI access then this is quicker :)
  • 13.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 08:50 PM
    I've added my IAP and assigned a licence to it. It doesn't appear in 'Monitoring' for anywhere except for 'Device Management', am I missing a step?
    Chris
  • 14.  RE: Aruba Central account and IAP Activation key
    Posted Oct 01, 2013 09:03 PM
    Chris - please send me your MAC address and I can take a look. How long has it been since you bound the device? It usually takes a couple of minutes before it starts checking in.
  • 15.  RE: Aruba Central account and IAP Activation key
    Posted Oct 02, 2013 07:25 AM
    @srinip,
    I've tried to ADD my IAP RAP-3WN and receive "failed to add the device". My MAC are 000b8682ea94.
    Can you check for me, please?
    Paulo Raponi
  • 16.  RE: Aruba Central account and IAP Activation key
    Posted Oct 02, 2013 08:07 AM
    I have the same problem with a IAP 105. This is my MAC address: d8c7c8cafb12
    Thank you!
  • 17.  RE: Aruba Central account and IAP Activation key
    Posted Oct 02, 2013 09:40 AM
    I still can't add my VC's.  Is this normal?  I know you were looking into it yesterday, is this still an issue today?
  • 18.  RE: Aruba Central account and IAP Activation key
    Posted Oct 02, 2013 09:42 AM
    I put in my cloud key and try the MAC in the following formats
    6c:f3:7f:ca:cd:83
    6cf3.7fca.cd83
    6cf37fcacd83
    it doesn't seem to matter.
    Any suggestions?
  • 19.  RE: Aruba Central account and IAP Activation key
    Posted Oct 02, 2013 10:16 AM
    I was able to add is using D8:C7:C8:C4:69:CC format. It's only got 1 trial license so I can't really do anything though.
  • 20.  RE: Aruba Central account and IAP Activation key
    Posted Oct 02, 2013 10:31 AM
    Thanks.  I tried to do it with all Caps and colon delimited as you did, but no joy.  I think I may be seeing the backend problem discussed on page 1.  I will keep trying.
  • 21.  RE: Aruba Central account and IAP Activation key
    Posted Oct 02, 2013 10:34 AM
    Now that my IAP shows up in Device Management and I have assigned the 1 license I have.
    How long before I see it on Central being monitored?
    Any way I can see traffic from the AP attempting to talk to Central?
    Anything special, like particular ports needing to be opened?
  • 22.  RE: Aruba Central account and IAP Activation key
    Posted Oct 02, 2013 12:36 PM
    Hello All,
    We are investigating each of these cases mentioned in the thread above. I will reach out to you individually to follow up.
  • 23.  RE: Aruba Central account and IAP Activation key
    Posted Oct 02, 2013 02:40 PM
    Add me to the list - MAC 24:DE:C6:C2:DF:0E
    Same Issues "Failed to add ..."
  • 24.  RE: Aruba Central account and IAP Activation key
    Posted Oct 02, 2013 02:45 PM
    My MAC is 00:0b:86:82:a2:97
  • 25.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 09:37 AM
    Can any of you try to the following:
    1. Provision a new AP into a new group and import the settings, call it A
    2. Create a new empty group in central, call it B
    Move your AP from Group A to Group B, your SSID should disappear since nothing is configured.
    Move you AP back to Group A and see if your IAP gets all of its settings back.
    My IAP is now asking for a country code, still retains the static IP it has. Did not configure a VC IP.
    I'm interested to know if someone else can reproduce this before I fire off an email.
    EDIT: Now I see a little red ! next to my AP and see the following screenshot (attached)
    I click on resolve and It does resolve the issue.
    Wondering why I need to resolve manually instead of having Central push automatically?
    EDIT (wow another edit...sorry):
    I did it again for a new group and same situation.
    Moving from group a to group c and then back to group a forces you to resolve manually.
    Not scalable in my opinion if you have hundreds of APs.
    Things I would like to see in Central:
    1. Group cloning (in order to save time configuring a new group_
    2. Under groups, possibly some folder structure in order to sort APs.
  • 26.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 01:19 PM
    @Pasquale
    1. Group Cloning is on the roadmap.
    2. I am unclear about the folder structure request. You should be able to sort APs from the Monitoring -> Access Points page. Please help me understand.
  • 27.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 01:35 PM
    @srinip wrote:
    @Pasquale
    Under the Andrei group (attached) you can see my AP, I am referring to adding folders under Andrei. If have a 5 different locations and would like to group my APs according to location by using folders.
    I can then easily navigate to the AP I want from there and it should bring me to the Access Point page.
    p.s. I can never attached pictures, it always says my post exceeds 20,000 characters/...
  • 28.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 02:16 PM
    Got it....let me describe the way I see your use case and you can tell me if this would suffice your requirement for now....
    1. The entries you see under each group in the left hand pane are for the Virtual Controllers (VC).
    2. You can click on the Virtual controller in the left hand pane and this will change the context in the main pane to be specific to that particular VC. So in other words...this would be analogous to the folder heirarchy you are mentioning.
    Assuming that you have 1 cluster (1 virtual controller with multiple APs) per location...the Virtual controller entry in the left hand pane under the group..becomes your folder! This enables you to share configuration across multiple virtual controllers (within a group) while giving you the flexibility to view information on a per VC basis.
  • 29.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 02:49 PM
    Perfect. Exactly. Said it better than I did
    I made the mistake of assuming those were APs to the left but yes they are VCs.
    "Assuming that you have 1 cluster (1 virtual controller with multiple APs) per location...the Virtual controller entry in the left hand pane under the group..becomes your folder! This enables you to share configuration across multiple virtual controllers (within a group) while giving you the flexibility to view information on a per VC basis."
    The group then would be for the customer and the VCs below it will be for individual locations for that customer. What happens if I don't name my VC appropriately and leave the default.
    I have no way of identifying which VC is for which location.
    If I had:
    Group A
    Site A
    VC
    Site B
    VC
    This would allow greater granularity.
    Does this make sense?
    Pasquale
  • 30.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 03:01 PM
    It does...we will definitely consider it.
    Thanks for the feedback!
  • 31.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 01:05 PM
    I too am having issues with adding any devices....."Failed to add the device" error message.
  • 32.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 01:13 PM
    What happens if I assign a license with my device using my account. I then remove this license for a particular AP.
    A colleague of mine logs in with his account, he does not see any of the devices registered to our company and therefore cannot assign a license to the same particular AP.
    How do we go about this?
  • 33.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 01:23 PM
    @Pasquale  reg: license.
    Your colleague should also be able to see the device list under Maintenance -> Device Management as long as he is an admin user. Please make sure he is looking under "All Groups" and not a speicfic group.
  • 34.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 01:32 PM
    Yes that worked thank you.
  • 35.  RE: Aruba Central account and IAP Activation key
    Posted Oct 03, 2013 04:59 PM
    Still can't add devices...  I am sure someone is working on it and all but maybe they could post some status updates?
  • 36.  RE: Aruba Central account and IAP Activation key
    Posted Oct 07, 2013 04:30 PM
    I cant add devices either, I'm getting the "failed to add device" messages as well.
  • 37.  RE: Aruba Central account and IAP Activation key
    Posted Oct 09, 2013 11:50 AM
    Has anyone noticed that when you remove a license from an AP, it takes a very long time for that AP to become unmanaged?
    It has been 20 min since I removed the license from Central and I still cannot make any changes on the AP itself
  • 38.  RE: Aruba Central account and IAP Activation key
    Posted Oct 09, 2013 12:40 PM
    Still not manageable.
    Since rebooting the AP via the CLI is allowed (not allowed in the webui)
    I rebooted it and now I can manage it.
  • 39.  RE: Aruba Central account and IAP Activation key
    Posted Oct 10, 2013 09:22 PM
    I can't add devices either, I'm getting the "failed to add device" messages .
    Cloud Activation Key: XAWBN3VS
    Mac Address: 24:de:c6:c3:44:7d
  • 40.  RE: Aruba Central account and IAP Activation key
    Posted Oct 11, 2013 03:37 AM
    Still having the same problem with Manually Add Device, got error message : "Failed to add the device."
    Here is activation code and MAC Address :
    N6OB3PXU
    24: DE:C6:C4:A7:6F
  • 41.  RE: Aruba Central account and IAP Activation key
    Posted Nov 09, 2013 11:24 PM
    I also cannot add devices. I have only tried my IAP in my home lab.
    MAC address: 6c:f3:7f:c6:2b:a4
  • 42.  RE: Aruba Central account and IAP Activation key
    Posted Nov 18, 2013 01:30 PM
    Hi
    My activation code is:       VYVBYQLG
    MAC ADR VC iAP            6c:f3:7f:c8:f9:53
    mesage:
    https://naw3.central.arubanetworks.com
    Whats is wrong here?
  • 43.  RE: Aruba Central account and IAP Activation key
    Posted Dec 03, 2013 10:42 AM
    I would like to bring this thread back to life. I am also failing to add devices to my cloud account and saw no resolution. I would really like to demo the cloud service.
  • 44.  RE: Aruba Central account and IAP Activation key
    Posted Dec 03, 2013 12:57 PM
    Hello folks,
    We have been resolving some of these corner cases where the IAP addition was failing over the past several weeks. I wanted to check in with the folks on this thread and see if anyone else is still running into this issue. If so, please send me your device MAC addresses and your Central login email address.
    Thanks for your patience.
    Srini
  • 45.  RE: Aruba Central account and IAP Activation key
    Posted Feb 20, 2014 11:45 AM
    Trying this on my RAP3WN, have reset it and tried three different recent releases (including 6.2.1.0-3.3.0.3) and never get a key.
  • 46.  RE: Aruba Central account and IAP Activation key
    Posted Nov 19, 2015 02:04 AM
    Hello all,
    I have the same Problem. I want to test Aruba Central. But i cannot add my Device.
    I get this errror "Device addition failed. Please retry adding device again after some time."
    My MAC is: 84D47EC11DC4
