So they are not able to open a browser and try accessing an external site? This should redirect if you are assigning a captive portal. Is DNS allowed for the client prior to the terms acceptance?
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: Jun 19, 2024 05:06 AM
Subject: Aruba Central and Clearpass - Cisco Anyconnect Always on
I have a new build with an Aruba Central deployment using Clearpass as the Web Portal page to accept Terms and Conditions before being granted internet access. After first login with acceptance of terms, MAC Address authentication applies with no problem. This works without issue.
I have some Cisco Anyconnect users who have an issue though. It seems that when they attempt to connect to the network they cannot connect - Clearpass has the mac address whitelisted as part of the logon and as an approved device. I think the laptops of concern are attempting to connect straight out to terminate their VPN without allowing the connection to the wifi to complete - unless they set captive portal remediation which apparently they don't have the capability to this.
Is there anything that can be done that would allow these specific MAC addresses out without the clearpass level - a new hidden SSID locked to MACs on Aruba Central rather than Clearpass that has a completely open connection but provides DHCP?
Regards
Adrian
Is there any way I can allow devices
