Aruba Central AOS10 Guest Captive Portal-Tunnel Mode
  • 1.  Aruba Central AOS10 Guest Captive Portal-Tunnel Mode
    Posted Jun 21, 2024 09:49 AM
    Anyone have any luck setting up a Guest WLAN that is tunneled to the Gateway from the Access Point. For some reason the Captive Portal page never shows up in Tunnel Mode. Bridge works fine but Tunnel mode is not working.
  • 2.  RE: Aruba Central AOS10 Guest Captive Portal-Tunnel Mode
    Posted Jun 23, 2024 10:13 PM
    you can check your configuration against this technote "Aruba AOS10 AP and Gateway Solution – Part3"
