Cloud Managed Networks
Aruba Central - AP rename using the CLI
  • 1.  Aruba Central - AP rename using the CLI
    Posted Aug 24, 2020 01:13 PM
    Hi All, I have over 200 IAPs split across to Sites.  I would like to rename each IAP to reflect the suite number it was installed into.
    I do see how to rename it through the Aruba Central GUI but would prefer a bulk method similar to the CLI on a local controller.
    Is this possible?
    Thank you!
  • 2.  RE: Aruba Central - AP rename using the CLI
    Posted Aug 24, 2020 02:02 PM
    This should be doable via Central APIs...
    Check this link in particular, it has an example on how to rename APs https://github.com/aruba/central-examples-only/blob/master/rest-api-python-scripts/central_modules/README.md
    Also, this link https://github.com/aruba/central-examples-only/tree/master/rest-api-python-scripts will give you the right start to use the REST APIs with Central
