HII've been playing around with the Aruba Central API and I'm trying to create a script that can get a list of all switches and then get all configured IP DNS servers. It seems those API do not exist? I've been looking for them in the API tester (Swagger) but the closest thing I'm finding is /configuration/v1/devices/{device_serial}/template_variables but it appears that it does not work for AOS-S devices as they return an empty result. Anyone that had some experience with this or was able to create a workaround? A copy of the running config would also work. Thanks!
