Developer
Aruba Central API: Configuring/Updating Access point Parameters
This thread has been viewed 33 times
  • 1.  Aruba Central API: Configuring/Updating Access point Parameters
    Posted Mar 07, 2021 04:12 PM
    Hi Guys,
    I am trying to update following parameters in AP setting.  Can someone help with this please.
    • AP Name
    • RF Zone
    • IP Address
    • Subnet Netmask
    • Default Gateway
    • DNS
    • Uplink VLAN
    But the only options i can see are below.
    API Endpoint Path: /configuration/v2/ap_settings/{serial_number}
      "hostname": "<ap-name>",
      "ip_address": "<ip-address>",
      "zonename": "<zone-name>",
      "achannel": "<achannel-num>",
      "atxpower": "<atxpower-num>",
      "gchannel": "<gchannel-num>",
      "gtxpower": "<gtxpower-num>",
      "dot11a_radio_disable": <true/false>,
      "dot11g_radio_disable": <true/false>,
      "usb_port_disable": <true/false>
    Tariq
    Tariq Shaikh
  • 2.  RE: Aruba Central API: Configuring/Updating Access point Parameters
    MVP GURU
    Posted Mar 08, 2021 06:50 AM
    Do you have look :
    https://eu-apigw.central.arubanetworks.com/swagger/central/#!/AP_Configuration/api_ap_clis_update_ap_settings_clis ?
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Aruba Central API: Configuring/Updating Access point Parameters
    Posted Apr 08, 2021 02:13 PM
    Hi Tariq,
    Could you tell us if you are using a UI group or a Template group to manage your Access Points ? That would help me redirect you to the respective API endpoints.
    Jay Pathak
