Cloud Managed Networks
Aruba Central application visbility no data
  • 1.  Aruba Central application visbility no data
    Posted Jul 08, 2020 05:55 AM
    Hello, im currently trying out the 90 days Aruba Central trial. i would like to see application and web usage globally and per-AP. But these are the only thing that shows up:
    However, i am able to see application usage per CLIENT:
    How do i fix this? Thank you
  • 2.  RE: Aruba Central application visbility no data
    Posted Jul 08, 2020 06:33 AM
    Did you try to select the right filter on the top left? You can select a group, site, device...etc.
  • 3.  RE: Aruba Central application visbility no data
    Posted Jul 08, 2020 06:35 AM
    Hi Ayman,
    Yes, i already did it. The first picture is from the virtual controller, the second is from global (all devices)
  • 4.  RE: Aruba Central application visbility no data
    Posted Jul 08, 2020 06:43 AM
    Yes sorry.. I noticed that after replying! Is this a new installation?
    Did you try to change the time filter on the top right? Did you try from a different browser?
  • 5.  RE: Aruba Central application visbility no data
    Posted Jul 08, 2020 06:52 AM
    Hi ayman,
    Yes this is a new installation, and i already tried to change the time filter and browser. still no good
  • 6.  RE: Aruba Central application visbility no data
    Posted Jul 09, 2020 03:18 AM
    What type of AP(s) are you using?
    What version of firmware are you running on the AP?
    Also, do you have AppRF (Deep Packet Inspection) enabled under Services?
  • 7.  RE: Aruba Central application visbility no data
    Posted Jul 09, 2020 04:01 AM
    Hi Herman,
    I am using IAP-325 with 8.6.0.4 firmware running.
    Yes, I have enabled DPI.
