Aruba Central - assign iap (access point) to another group while online
  • 1.  Aruba Central - assign iap (access point) to another group while online
    Posted Oct 24, 2019 04:50 PM
    As the title states.
    Assign a AP to another Group which is already online.
    I can't delete the AP cause its online.  (Deleting a AP is a chore btw)
    I can revoke the subscription, but that seems excessive.
    I'll explain what I want to achieve.
    I have a P2P to a house that I have a IP-305 access point that I want to broadcast a seperate set of SSID.   I assigned the wrong group to it, and instead of provisioning another AP and have the user connect that, I'd rather have a less intrusive way to change the Group on that AP.
    SMX
  • 2.  RE: Aruba Central - assign iap (access point) to another group while online
    Posted Oct 30, 2019 12:37 PM
    Problem Resolution:
    Issue : Need to move a device from one group to another in Central.
    Troubleshooting :
    • Went on a remote session and took the Central page.
    • Since it was a slave AP we made it as a Standalone AP and then mapped it to a new group.
    Steps to move the device from one group to another in central  :
    Global settings -> Managed groups : Select the group from which the device has to moved and we will see the VC listed on the right.
    Drag and drop the VC to the group to which it has to be mapped.
