Cloud Managed Networks
Aruba Central Bugs/Freeze Ups
  • 1.  Aruba Central Bugs/Freeze Ups
    Posted Mar 25, 2021 04:37 PM
    I keep experiencing random UI issues with Aruba Central during change windows, and it's getting quite aggravating. Below are some that I can think of off the top of my head, and the one I've had the time to document.
    - Random "Server 500" errors when navigating around
    - Random tabs don't load when clicking on them
         - IAP VC > Devices > Config
               - WLANs, Access Points, Interfaces are just blank
    For reference, I'm building this VC for a new office, and I cannot get in to rename the APs that join from their default name of the MAC. And yes, I've closed out my browser, deleted cookies, restarted my PC, tried different browsers, etc.
    Sections of Central just randomly don't load or the settings take forever to sync and show up. I just have to abandon that part of the configuration process until I check in later and it magically loads.
    Previously, an SNMP push from Central completely wiped all my on prem device's configurations and then wiped out the Central configs as well. While trying to rebuild in Central, I kept getting Server 500 errors, and after 8 hours on the phone with TAC, I gave up, disabled aruba central on everything, and hand jammed the configs for 20+ devices because nobody had an answer on what caused Central to push a blank config to my devices and wiped the configs from the cloud.
    Does anyone else have similar issues with the Central UI or is it just me?
    Thomas Newlon
  • 2.  RE: Aruba Central Bugs/Freeze Ups
    Posted Mar 31, 2021 11:53 AM
    Thomas,
    Do you still see this behavior? I don't think this is common and TAC should be able to find the root cause. I work on a pre-production cluster and have seen such things only long time ago and it was quickly fixed which is why there is a pre-production cluster to don't have issues in production. Do you have a local Aruba SE that you can reach out to, so this can get the proper attention? If not, can you share the TAC case number and your location/contact details in a personal message, so I can see if there is a local representative?
  • 3.  RE: Aruba Central Bugs/Freeze Ups
    Posted Mar 31, 2021 05:07 PM
    Hey Herman!
    Thanks for reaching out. The "Server 500" behavior is intermittent, and I can't really replicate it reliably. Just randomly will pop up, and a webpage refresh/log out fixes it. As for the VC page errors, I did open a TAC case and by the time the engineer got to it, the issue was not replicable. They did mention that there was a "temporary glitch when you were trying to access the configuration in the past" and after that, everything moved along smoothly in my deployment.
    The previous SNMP push/wipe was a nightmare, and after that issue, I am more proactive with looping in my local SE and territory manager when things get squirrely.  They've been very responsive any time I've engaged them since. Can't say enough good things about them, honestly.
    Thomas Newlon
