Cloud Managed Networks
Aruba central - can't add AP to site floorplan
  • 1.  Aruba central - can't add AP to site floorplan
    Posted Mar 10, 2022 01:37 PM
    Hi everyone,
    I have a weird issue.  I have a site defined in Aruba Central, that has 12 Ap505s assigned to it.  In the floorplan view, when I try to add deployed AP's, I only see 9 of them.  I've checked the site details, and I can see all of the APs there.  I've made sure that when I try and add the AP's, the "hide aps that are already added" is unchecked.  Has anyone come across this before?
    Shaun Raven
  • 2.  RE: Aruba central - can't add AP to site floorplan
    MVP GURU
    Posted Mar 10, 2022 03:59 PM
    Did you check top see if it was deployed on another map/floorplan? I have done that to myself a couple times....
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Aruba central - can't add AP to site floorplan
    Posted Mar 11, 2022 04:08 AM
    Figured it out - the AP wasn't licensed, therefore it wouldn't allow it to be deployed - once licenced, it appeared!
    Shaun Raven
