How can I change the PVID (default 1) of my switch from Central.
I want different VLAN mgmt ID (ex: 10).
It' s possible change this parameter only from Central, without configure switch via CLI?
yes you should be able to do this by using template based configuration in Aruba Central. Also ensure when you configure the new VLAN, Aruba Central is reachable through it.
