I don't have personal experience (and no access to a ChromeOS 115 or later), but documentation is here.
And in Play there is a ClearPass Onboard and an Aruba Onboard App.. the last one is the one you need.
Do you get a specific error that makes the app not to install?
Original Message:
Sent: Nov 02, 2023 10:01 AM
Subject: Aruba Central Cloud Auth and Chromebooks
Has anyone successfully managed to onboard Chromebooks with the Aruba Central Onboard app?
According to the documentation ChromeOS 115 or later is supported, but I cannot install the app on the device.
I've set up "Authentication & Policy" connection with Google Workspace, created SSID that use the Cloud Auth server, and connection/authentication works fine with an iPhone.
Any advice is much appreciated
Many thanks
Tom
