I'm trying Aruba Central Configure Alerts, when I search Aruba Central don't find anything...
¿Has someone any idea for help me?
I want to test the new webhook feature.
Thanks.
You can find the Webhook under Maintenance > API Gateway > Webhook.
Alerts can be found under Monitoring & Reports > Alerts
Thank you zalion0,
I know the menú and the routers... but in Configure Alerts nothing is shown. Time ago here I could to choose several alerts types.
I attach a capture.
That's odd, I do not see the same issue here. Which browser are you using? Works fine for me with Firefox...
I'm using Firefox Quantum 62.0.3 (64-bit). I'm going to try reboot mi laptop.
This link should give you a good indication on how Webhook works:
http://help.central.arubanetworks.com/2.4.6/documentation/online_help/content/pdfs/central/aruba_central_and_servicenow_integration.pdf
