Aruba Central - convert the IAP to controller based
  • 1.  Aruba Central - convert the IAP to controller based
    Posted Jun 27, 2014 12:33 PM
    What happens if customer has purchased an Aruba Central subscription for their IAP cluster and then they convert them to controller based APs.
    They are looking to put in a 7005 controller for a bit extra functionality.  Can these controllers be added to Central?  For that matter, why are they called 'cloud controllers'?
    #7005
  • 2.  RE: Aruba Central - convert the IAP to controller based
    Posted Jun 27, 2014 12:36 PM
    Not currently
  • 3.  RE: Aruba Central - convert the IAP to controller based
    Posted Jun 27, 2014 01:52 PM
    "What happens if customer has purchased an Aruba Central subscription for their IAP cluster and then they convert them to controller based APs."
    ___________________________________________
    If an IAP Cluster has been converted to controller-based you can remove them from Central management thus freeing up their Central subscription licenses for use by other IAPs.
  • 4.  RE: Aruba Central - convert the IAP to controller based
    Posted Jun 28, 2014 05:43 AM
    I guess what I'm asking is can the subscription be cancelled, and would there be credit due back?
  • 5.  RE: Aruba Central - convert the IAP to controller based
    Posted Jun 30, 2014 03:38 AM
    I had the same issue, no cancellation allowed but local sales can give some discount on the controller etc. Work it out with the sales.
  • 6.  RE: Aruba Central - convert the IAP to controller based
    Posted Jun 28, 2014 06:41 AM
    Unfortunately, no.
