Original Message:
Sent: Jul 22, 2024 10:14 AM
Subject: Aruba Central - Device internal error
I don't have an out of sync device, but remember that there is a side-by-side comparison where you can see (only) the differences, or with a markup on the different lines. Don't you have that??
Original Message:
Sent: Jul 22, 2024 07:15 AM
Hi Herman,
Thank you for your feedback.
Indeed, the logging shows that the stack lost its connectivity to Central (on the mgmt VRF it happened when I disconnected all the MGMT interfaces from the old network; this way I did the initial configuration and I kept a "back door" in case something was going wrong on VLAN 1).
In any case, the switches are still connected to Central using the default VRF (they show "online" in the list and I can use the Aruba Central console connection to this switch to make changes (after enabling aruba-central support mode).
Here is the output of the "Configuration Status" for the "Not in Sync Device":
And this is the current running configuration taken from the switch:
All the switches are on the latest recommended firmware (ML 10.13.1010)
Original Message:
Sent: Jul 22, 2024 05:54 AM
The logging suggests that the switch cannot reach Central anymore (through the default VRF). Could it be that your change blocked access to Central? Or another network change (firewall?) blocked access from your switch to central?
It seems that you use template based configuration. Does the Configuration Audit (go in your config group; select switches, configuration, Configuration Audit tab) explain more about what is out of sync or what commands provide errors?
Original Message:
Sent: Jul 22, 2024 03:22 AM
Last week I have rolled out five new 6200F switches for one of our customers. There are two VSF stacks of two switches each and one stand-alone switch. All the configuration is done via a template and a variable configuration file; everything went fine up to a point when, suddenly, one of the stacks went out of sync.
After each change I make to the template or after uploading a new variable configuration file, I get the error shown below.
Clicking the three dots doesn't reveal much:
I ahve also checked the events - nothing relevant there.
And here is the log from the switch console:
The error first showed on the 17/07.
I should highlight that the configuration template applies to both stacks and to the stand-alone switch. The other stack and the stand alone switch are "In sync" with no issues.
I Have opened a support case with Aruba TAC and they suggested to create a new, test group and move the "faulty" stack there, to see if the issue persists.
Has anyone else encountered this error?
