Aruba Central disconnect
  • 1.  Aruba Central disconnect
    Posted Dec 05, 2013 10:09 AM
    I am currently trying a demo of Aruba Central. I am experiencing some trouble disconnecting an IAP 105 from Central. I am unable to select the device management portion of the GUI.
    What would be the cause of being unable to select device management?
  • 2.  RE: Aruba Central disconnect
    Posted Dec 05, 2013 10:12 AM
    Currently, you must reboot your IAP to restore local WebUI access once connectivity to Central is blocked.
    This behavior will change soon so a reboot will not be necessary.  The timeout value is currently 15 minutes.
  • 3.  RE: Aruba Central disconnect
    Posted Dec 05, 2013 10:21 AM
    Perfect. Thanks
  • 4.  RE: Aruba Central disconnect
    Posted Nov 06, 2014 08:20 AM
    Hi guys,
    Is there any update about this problem? we want to temporarly disconnect the VC from Aruba central but even after pausing Aruba central on vc gui we are not able to get gui access and it shows the status as connected.
    Thanks!
