Aruba Central documentation
  • 1.  Aruba Central documentation
    Posted Jun 19, 2014 02:18 AM
    Is there any documentation around setting up Aruba Central?
    I guess I'm looking mainly for details on what firewall rules need to be to allow that communication between Central and the IAP cluster?
  • 2.  RE: Aruba Central documentation
    Posted Jun 19, 2014 08:49 AM
    Can`t seem to find a datasheet with ports but this is from the Instant 4.1 user guide.
    "Aruba Central uses a secure HTTPs
    connection and provides a strong mutual authentication mechanism using certificates for all communication with
    IAPs. These certificates ensure the highest level of protection."
  • 3.  RE: Aruba Central documentation
    Posted Jun 19, 2014 09:50 AM
    Please allow NTP to pool.ntp.org and HTTPS access to all sites.
  • 4.  RE: Aruba Central documentation
    Posted Jun 20, 2014 02:10 AM
    Thanks.  I figured it was going to be https.
    The inbound connection to the IAPs, just need to allow from portal.central.arubanetworks.com?  Is that correct?
  • 5.  RE: Aruba Central documentation
    Posted Mar 25, 2020 03:02 AM
    https://help.central.arubanetworks.com/latest/documentation/online_help/content/nms/device-mgmt/communication_ports.htm
    Here is the documentation. So far i found 2 more undocumented DNS Hosts to add.  And did not allow port 2083 since it schould fail back to 443.
    There should no incoming firewall rule needed since the APs poll central for changes.
    Still testing on this today
