Cloud Managed Networks
Aruba Central - expiring licences for APs and switches
  • 1.  Aruba Central - expiring licences for APs and switches
    Posted May 05, 2022 01:01 PM
    We have expiring licences for switches (2930M) and AP's in Aruba Central.
    We're are trying to match the serial number of the device with the subscription key. Is there a way to extract this information?
    The GUI doesn't have the correct fields displayed.
    Can the TAC pull a custom report or can we use one of the API's to pull the information for a report.
    Stephen Elias
  • 2.  RE: Aruba Central - expiring licences for APs and switches
    Posted May 05, 2022 02:50 PM
    Hi Stephen,
    I'm not sure you can. Awhile back I needed to know as well because I had to do an auditing across departments and the TAC engineer told me that when it comes to subscriptions or assign licenses, it basically works as a pool. Just like a DHCP server with devices getting IP's dynamically, first come first serve.
    But if there is an option, I would like to know as well. Notice that when you assign licenses the system doesn't ask from which subscription keys to distribute from.
    Selomon Kifle
  • 3.  RE: Aruba Central - expiring licences for APs and switches
    Posted May 06, 2022 07:51 PM
    yes it works as a pool. just add the new subscription licenses and Central will automatically use them after the expiry date of the previous lics.
