Cloud Managed Networks
Aruba Central - How to view the bandwidth usage per client
  • 1.  Aruba Central - How to view the bandwidth usage per client
    Posted Sep 14, 2018 11:20 AM
    I am trying to figure out how to view a graph showing the bandwidth usage per client in Aruba Central.
    In Monitoring & Reports / Client Overview, there is a bandwidth usage graph of all clients aggregated, but if I go to List and select one of the client, I don't get a graph, just some information:
    USAGE & RF HEALTH
    • SIGNAL STRENGTH
      68 dBm
    • SIGNAL TO NOISE RATIO (SNR)
      24 dB
    • SPEED
      150 Mbps
    • CHANNEL / BAND
      116E / 5 GHz
    I guess that's where it should show the graph over the time range selected...but there is nothing.
    When I look at the Central training videos it's not the same version of Aruba central and it works fine, so perhaps it is not implemented in the new version ?
  • 2.  RE: Aruba Central - How to view the bandwidth usage per client
    Posted Sep 21, 2018 04:54 AM
    you are correct, this information is not presented in the current Dashboard that was re-worked over previous versions.
    I will raise this internally as potential enhancement.
