Aruba Central Instant EAP-PEAP RADIUS EAP Timeout
This thread has been viewed 22 times
  • 1.  Aruba Central Instant EAP-PEAP RADIUS EAP Timeout
    MVP EXPERT
    Posted May 15, 2021 06:29 PM
    Hi Guys iam driving crazy to find a issue i normally don't have any issues with. I try to configure a very easy straightforward WPA2-Enterprise (EAP-PEAP) in an Aruba instant cluster managed by central. For some reason WPA2-Enterprise turns every time in an EAP time out issue in the ClearPass event logs. I configured this many times without issues and now iam struggling for about 8 hours (grrr).
    Error Code 9002 RADIUS Client did not complete EAP transaction
    I re-install anything out of frustrating. Re-install a new instant group in Aruba Central and re-install ClearPass to be sure. It's not a client side issue. Didn't had any issues with the ClearPass configuration before. I guess i do something wrong in the Aruba Central part because since i move to a new central account when the issue appear.
    ArubaOS Instant 8.6.0.9
    ClearPass 6.9.5
    IAP-325
    AP-505
    Find my config below.. Hope somebody have a clue...
    Zaltbommel-AP02# show run
    version 8.6.0.0-8.6.0
    virtual-controller-country NL
    virtual-controller-key *********
    name Zaltbommel-VC
    virtual-controller-ip 172.16.200.240
    virtual-controller-vlan 200 255.255.255.0 172.16.200.254
    virtual-controller-dnsip 172.16.200.1
    terminal-access
    ntp-server 0.nl.pool.ntp.org
    clock timezone Amsterdam 01 00
    clock summer-time CEST recurring last sunday march 00:00 last sunday october 03:00
    rf-band all
    dynamic-radius-proxy
    dynamic-tacacs-proxy
    report-rssi-to-central unassociated-and-associated-clients
    allow-new-aps
    allowed-ap d0:15:a6:c3:cd:8e
    allowed-ap f0:5c:19:ca:49:22
    arm
    wide-bands 5ghz
    80mhz-support
    a-channels 100,104,108,112,100+,108+,100E
    min-tx-power 15
    max-tx-power 15
    band-steering-mode prefer-5ghz
    air-time-fairness-mode default-access
    channel-quality-aware-arm-disable
    client-aware
    scanning
    rf dot11g-radio-profile
    max-distance 0
    max-tx-power 9
    min-tx-power 6
    disable-arm-wids-functions off
    free-channel-index 40
    rf dot11a-radio-profile
    max-distance 0
    max-tx-power 18
    min-tx-power 12
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    hash-mgmt-password
    hash-mgmt-user admin password hash *******
    wlan access-rule HomeLAB-IOT
    utf8
    index 0
    rule any any match any any any permit
    wlan access-rule default_wired_port_profile
    index 1
    wlan access-rule wired-SetMeUp
    index 2
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule HomeLAB-Corp
    utf8
    index 3
    wlan ssid-profile HomeLAB-IOT
    enable
    index 0
    type employee
    essid HomeLAB-IOT
    utf8
    wpa-passphrase **********
    opmode wpa2-psk-aes
    max-authentication-failures 0
    vlan 201
    auth-server InternalServer
    rf-band all
    captive-portal disable
    dtim-period 1
    broadcast-filter none
    g-min-tx-rate 24
    a-min-tx-rate 24
    blacklist
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan ssid-profile HomeLAB-Corp
    enable
    index 1
    type employee
    essid HomeLAB-Corp
    utf8
    opmode wpa2-aes
    vlan 201
    auth-server ClearPass
    rf-band all
    dtim-period 1
    broadcast-filter arp
    g-min-tx-rate 24
    a-min-tx-rate 24
    blacklist
    auth-survivability cache-time-out 24
    wlan auth-server ClearPass
    ip 172.16.200.2
    port 1812
    acctport 1813
    key *************
    nas-ip 172.16.200.240
    wlan captive-portal
    background-color 16777215
    banner-color 15329769
    decoded-texts banner/terms/policy
    banner-text "Welcome to Guest Network"
    terms-of-use "This network is not secure and use it at your own risk."
    use-policy "Please read and accept terms and conditions and then login."
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    wired-port-profile wired-SetMeUp
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-SetMeUp
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    no shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
    clarity
    inline-sta-stats
    inline-auth-stats
    inline-dhcp-stats
    inline-dns-stats
    cluster-security
    allow-low-assurance-devices
    Zaltbommel-AP02#
    Marcel Koedijk | MVP Guru 2021 | ACMP | ACCP | ACDA | Ekahau ECSE | Not an HPE Employee | Opionions are my own
  • 2.  RE: Aruba Central Instant EAP-PEAP RADIUS EAP Timeout
    MVP EXPERT
    Posted May 15, 2021 08:01 PM
    Update...
    By removing the NAS IP Address, disable the Dynamic RADIUS Proxy and add both access points directly into the ClearPass devices i got things worked.
    Not very suitable solution for larger production environments offcourse. Maybe i run into this known issue but i have to further investigate it.
  • 3.  RE: Aruba Central Instant EAP-PEAP RADIUS EAP Timeout
    MVP EXPERT
    Posted May 16, 2021 01:13 PM
    Update...
    Finally i figure it out... As always the solution was quite simple. I probably made the same mistake a long time ago.
    The solution was that some fields must be empty when configure the Virtual Controller IP on the same native vlans as the IAP's.
