Cloud Managed Networks
Aruba Central - Lost connection with 9 IAP's
  • 1.  Aruba Central - Lost connection with 9 IAP's
    Posted May 14, 2020 07:36 PM
    we lost connection with 9 IAP's.
    This is the status of the IAP's:
    show ap debug cloud-server
    IAP mgmt mode :athena-mgmt login
    cloud config recved :TRUE
    autojoin mode :disable
    state diff :disable
    Device Cert status :SUCCESS
    Aruba Central server :app1.central.arubanetworks.com
    Aruba Central Protocol :HTTPS
    Aruba Central status :Connecting
    Aruba Central fail reason :SSL ca cert error
    Aruba Central fail times :3
    show activate status
    Cloud Activation Key :
    Activate Server :device.arubanetworks.com
    Activate Status :connection-failed
    Activate fail reason :SSL ca cert error
    Provision interval :5 minutes
    Is there a fix for my problem ?
  • 2.  RE: Aruba Central - Lost connection with 9 IAP's
    Posted May 14, 2020 10:18 PM
    Did you get all the warning emails about upgrading your IAP software? What version of code is running on these IAPs?
  • 3.  RE: Aruba Central - Lost connection with 9 IAP's
    Posted May 15, 2020 02:32 AM
    I did run a local update on the iap's to version 8.5.0.3_72498.
    But still no connection to aruba central.
    I did not receive a warning e-mail.
    Do you have a link to this e-mail ?
  • 4.  RE: Aruba Central - Lost connection with 9 IAP's
    MVP EXPERT
    Posted May 15, 2020 03:47 AM
    You'll need to upgrade to up 8.5.0.5 and higher. The issue is present in IAPs running 8.5.0.x prior to 8.5.0.5.
    *EDIT* Added the NOT affected products.
    IAPs running Instant version
    - 8.6.0.2 and higher
    - 8.5.0.5 and higher
    - 8.4.0.6 and higher
    - 8.3.0.11 and higher
    - 6.5.4.15 and higher
    - 6.4.4.8-4.2.4.16 and higher
