SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
Aruba Central managing controllers
This thread has been viewed 19 times
  • 1.  Aruba Central managing controllers
    Posted Nov 13, 2016 09:57 AM
    Will aruba central manage controllers? or already does?
    In the datasheet it says
    i see on the datasheet of the aruba central saying this:Aruba’s complete cloud network solution includes Aruba Central, our cloud-based network management solution, along with Aruba’s portfolio of Instant access points, ArubaOS switches, and Aruba Mobility Controllers. All managed from the cloud.
    Cheers
    Carlos
  • 2.  RE: Aruba Central managing controllers
    Posted Nov 13, 2016 07:26 PM
    No controllers are managed by Central, Central can manage the Instant Virtual Controller, but not hardware controllers (7000 and 7200).
  • 3.  RE: Aruba Central managing controllers
    Posted Nov 13, 2016 09:17 PM
    Why it says aruba mobility controllers then?
  • 4.  RE: Aruba Central managing controllers
    Posted Jan 20, 2017 12:20 PM
    I am also confused by this. Can this manage the "Cloud Series" mobility controllers, like 7005 ?
  • 5.  RE: Aruba Central managing controllers
    Posted Jan 21, 2017 08:31 AM
    Aruba central can only manage the following:
    Aruba Instant APs
    Aruba MAS
    Aruba Switches
    Get Outlook for iOS
  • 6.  RE: Aruba Central managing controllers
    Posted Mar 12, 2017 11:23 AM
    Dear All,
    Have any update ?
    Can  ARUBA CENTRAL manage ARUBA controller ?
  • 7.  RE: Aruba Central managing controllers
    Posted Mar 13, 2017 08:42 AM
    i bealive they willl suppport 7000 series but not yet...
    So the answer right now is no they do not support controllers.
    Cheers
    Carlos
  • 8.  RE: Aruba Central managing controllers
    Posted Oct 18, 2017 04:42 AM
    Any updates on this issue ?
    I have a client who might have the need to manage a controller based solution as well as a remote instant cluster with central
  • 9.  RE: Aruba Central managing controllers
    Posted Feb 21, 2018 11:59 AM
    Doesn't Central act as a cloud based controller? You shouldn't need controllers at all if you're using Central, right?
  • 10.  RE: Aruba Central managing controllers
    Posted Feb 22, 2018 07:23 PM
    Central is not a cloud based controller. Its cloud based management solution for devices such as Controllers, Instant APs.
  • 11.  RE: Aruba Central managing controllers
    Posted Jul 27, 2018 02:53 PM
    So, based on the last comment, it sounds as if Central DOES manage 7005 controllers. Correct?
  • 12.  RE: Aruba Central managing controllers
    Posted Aug 07, 2018 03:36 AM
    No, that's not correct. WLAN controllers can't be managed by Aruba Central.
    However, since the Aruba SD-WAN solution was introduced last month, Central can manage SD-WAN gateways. SD-WAN gateways use the same hardware as WLAN controllers but a different software. You can find much more information about Aruba's new SD-WAN solution in the link below:
    https://www.arubanetworks.com/products/networking/sd-wan/
  • 13.  RE: Aruba Central managing controllers
    Posted Nov 09, 2018 10:53 AM
    So we're going to manage our 7010s and some 7008's in Central.
    We haven't been told it can't by our Aruba SE, and we've been testing along those lines.
    May have been a recent improvement.
  • 14.  RE: Aruba Central managing controllers
    Posted Nov 10, 2018 12:48 PM
    There's a slight confusion here.
    As part of our SD-Branch solution we're using the same hardware with a different software to act as branch gateway. This new software version has all the features of our old controllers (role-based FW, NAT, AAA, routing, tunnels, etc) except for the WLAN part.
    Instead of it, we have added a lot more "WAN-specific" features such as dynamic path steering, NAT 1:1, DNS redirect, integration with cloud security solutions, improved HA (we now support active-active WAN between 2 gateways) and a long list of additional features.
    So, even if it's the same HW, we don't have a cloud managed WLAN controller. What we have is a cloud managed branch gateway.
    I hope this makes sense
