Cloud Managed Networks
Aruba Central Max number of devices it can support
  • 1.  Aruba Central Max number of devices it can support
    Posted Jun 10, 2018 07:29 AM
    Hi Experts,
    Any idea what is the maximum number of devices Aruba Central can handle?
  • 2.  RE: Aruba Central Max number of devices it can support
    Posted Jun 11, 2018 11:15 AM
    I'm not aware of any practical limits on device numbers in central. Note that when deploying Aruba Instant APs via Central, there are design constraints on cluster sizing. You should follow the Aruba Instant VRD for guidance on the low-level design, especially if you exceed 15-25 APs in a cluster.
    If you think that you have a design with thousands of AP's in central, it may make sense to contact your local Aruba SE.
  • 3.  RE: Aruba Central Max number of devices it can support
    Posted Jun 24, 2018 11:19 PM
    We have customers with close to 100.000 APs in Central (which usually means 10x client devices) and are not running into any performance issues. So virtually unlimited.
