last person joined: 8 hours ago
Aruba Central MSP View - can not change AP Name
  • 1.  Aruba Central MSP View - can not change AP Name
    Posted Feb 07, 2018 05:03 AM
    We have Sophos central with MSP view activated. But i am missing the options to configure e.g. AP Names and Settings.
    In Wireless Managemant App i can only see "Wireless Networks", "RF", "Security"  and so on.
    The Central user guide says:
    1. Click Configuration > Wireless.
    2. Select a group and then click Access Points. The Access Points page is displayed.
    3. Click the AP that you want to customize.
    4. Click Edit. The Edit pane for modifying the AP details is displayed.
    But i can not find any of that buttons
  • 2.  RE: Aruba Central MSP View - can not change AP Name
    Posted Feb 12, 2018 02:59 PM
    Have you created customers? If yes, click on the customer ID and transition from MSP Interface to Customer Interface.
    Then change the app to wireless management > Access Points.
    Check attached picture.
  • 3.  RE: Aruba Central MSP View - can not change AP Name
    Posted Feb 13, 2018 02:48 AM
    i tried like you said but still can not find that point. I also attached a screenshot
  • 4.  RE: Aruba Central MSP View - can not change AP Name
    Posted Feb 13, 2018 05:20 PM
    You are in the MSP interface I suppose. That is why you do not see that "Access Points" as an option in the navigation menu.
    Go to "All Customers"
    Click on the tenant number. That moves you to the tenant view, where the option should be there.
  • 5.  RE: Aruba Central MSP View - can not change AP Name
    Posted Feb 15, 2018 07:16 AM
    it did not work like you said, but since today it works. Today or yesterday nicht was an update of central :)
