Network Management
last person joined: 11 hours ago
Aruba Central on-premsie integration with cyberArk
This thread has been viewed 32 times
  • 1.  Aruba Central on-premsie integration with cyberArk
    Posted May 09, 2023 10:45 AM
    I was in the process of deploying Aruba Cenral on-promise at one of our customer sites and they have CyberArk PAM deployed.
    Is it possible to integrate cyberArk with Aruba Central and if so would you please share a guide on how to do that.
    Thanks in Advance.
    Yadel B.
  • 2.  RE: Aruba Central on-premsie integration with cyberArk
    Posted May 09, 2023 11:03 AM
    Hi Yadel,
    Currently,  Aruba Central Om Premises do not support any 3rd party integrations.
    Regards
    Gowri Amujuri
  • 3.  RE: Aruba Central on-premsie integration with cyberArk
    Posted May 10, 2023 06:32 AM
    Thank you.
    What about the Cloud version of aruba central?. Can it integrate with CyberArk PAM?
  • 4.  RE: Aruba Central on-premsie integration with cyberArk
    Posted May 10, 2023 10:56 AM
    AFAIK, NO. Aruba Central does not have an option to integrate with CyberARK PAM.
    I would suggest working with your accounts team on the use case and open a Enhancement request accordingly.
    Regards
    Gowri Amujuri
  • 5.  RE: Aruba Central on-premsie integration with cyberArk
    Posted May 11, 2023 01:39 AM
    Thank you so much.
    But if i can ask you a couple of questions about central integrations.
    Does aruba central in-prem integrate with edgeconnect enterprise sd-wan. I have seen documentation of it integrating with the cloud version of aruba central atleast for monitoring purposes.
    Does aruba central integrate with Aruba Fabric composer if i deploy it at the data center. I mean can i monitor the dc switches through aruba central?.
    Thank you.
  • 6.  RE: Aruba Central on-premsie integration with cyberArk
    Posted May 11, 2023 01:56 PM
    Below link will provide the supported devices on Aruba Central
    https://www.arubanetworks.com/techdocs/central/latest/content/nms/overview/supported_devices.htm
    Devices can be anywhere on your network, it needs connectivity to Central. There's documented ports that needs to be opened on Aruba devices to communicate to Central. Once, they are open, Aruba devices at DC or Edge can connect to Aruba Central.
    Regards
    Gowri Amujuri
