Wireless Water Cooler
last person joined: 22 days ago
Hang out and socialize with other community members in this off topic forum. Everything from industry trends to hobbies and interests are welcomed!
Aruba central ports
  • 1.  Aruba central ports
    Posted Sep 21, 2016 09:29 AM
    I'm deploying an Aruba Central solution but I have a few issues with the firewall. When I try to register my AP on the Aruba Central without the firewall it's ok but when I replug it it doesn't work (the AP is not UP on the Aruba central dashboard).
    The AP can join the device.arubanetworks.com.
    I would like to know which port I need to open on my firewall.
    Thank You.
  • 2.  RE: Aruba central ports
    Posted Sep 21, 2016 11:16 AM
    Management/configuration and typical communications from the IAP/VC is done over HTTPs (TCP 443) to both device.arubanetworks.com (for Activate) and *.central.arubanetworks.com (for Central).
    TCP 80 is needed for some of the image upgrades to images.arubanetworks.com and rcs-m.central.arubanetorks.com.
  • 3.  RE: Aruba central ports
    Posted Oct 13, 2016 05:28 AM
    Hi there,
    I just want to add at this reply that you also need to open the 53170 (for the central authentication) and the 52258 (for the AP configuration).
    Not sure if others ports need to be open.
    Again thanks for your reply.
    Lucien
  • 4.  RE: Aruba central ports
    Posted Oct 13, 2016 06:06 AM
    Lucien,
    Where did you receive that information? It should all occur over port 443.
  • 5.  RE: Aruba central ports
    Posted Oct 13, 2016 06:13 AM
    Hi cjoseph,
    I first tried to connect my AP to the central without modify my firewall (the port 443 is allowed) and the ap cannot register on the aruba central.
    Then I launch a wireshark without any firewall and the device.arubanetworks.com seems to communicate with the AP with dest ports : 53170 and src ports : 443.
    Then my AP finally go up in the central but do not take the configuration.
    Then I double check my wireshark capture and the app1.central.arubanetworks.com seems to comunicate to my AP with the dest port : 52258 and then it's work.
    I hope I've been clear with my explanation, maybe I did something wrong.
    Lucien
  • 6.  RE: Aruba central ports
    Posted Oct 13, 2016 06:44 AM
    Lucien,
    What kind of firewall do you have?  Those ports almost seem like a source port that was a reply to the port 443 request.
  • 7.  RE: Aruba central ports
    Posted Oct 13, 2016 08:09 AM
    cjoseph,
    I use a Palo Alto FW.
  • 8.  RE: Aruba central ports
    Posted Oct 13, 2016 09:06 AM
    Ok, I was in a rush sorry.
    I just not enough waited....
    I try again without the ports open and after a while everythings seems alright.
    Sorry for that and thanks for your answer.
    Lucien
