Aruba Central - Re-assign AP to different subscription key
  • 1.  Aruba Central - Re-assign AP to different subscription key
    Posted Oct 18, 2016 09:30 PM
    Just received our Aruba Central subscription key - is there a way to move an AP from the trial subcription key to the real one?
  • 2.  RE: Aruba Central - Re-assign AP to different subscription key
    Posted Oct 18, 2016 09:56 PM
    If that AP is in your Activate account you can sync Central with activate using your Activate credentials and re-assign the license under Network Management > Maintenance > Device Provisioning
    If you haven’t created an Activate Account you can go to activate.arubanetworks.com and create an account using the serial and mac address of the AP
