Cloud Managed Networks
  • 1.  Aruba Central - Rename Groups
    Posted Jun 19, 2024 05:02 PM
    Is it possible to rename a Group in Central? I have a VPNC group set up how I want it for the clustered VPNCs, and now want to change the naming.
    In AOS8.x with MC I know what I would do. But without CLI access to Central itself, I don’t know how to do this.
  • 2.  RE: Aruba Central - Rename Groups
    Posted Jun 19, 2024 07:51 PM
    no you can't rename an existing group in Central but you can create a new one and move the devices to it while retaining their configuration.
  • 3.  RE: Aruba Central - Rename Groups
    Posted Jun 19, 2024 09:10 PM
    I would be fine with going that route, but do I have to be concerned with any information being lost or functionality broken?
    I have micro branches terminating to the VPNC cluster and doing CL2 WLANs. I imagine those will break?
    ryh
  • 4.  RE: Aruba Central - Rename Groups
    Posted Jun 19, 2024 10:13 PM
    for dedicated group for MB,  it should be fine. test it with one and see.
