Cloud Managed Networks
Aruba central sms
  • 1.  Aruba central sms
    Posted Dec 21, 2017 10:33 AM
    Does aruba central have unlimited sms plan? or do i have X amount of SMS he can send per month or year?
    Cheers
    CArlos
  • 2.  RE: Aruba central sms
    Posted Dec 22, 2017 03:58 AM
    Carlos,
    There is no hard limit on the number of SMS messages used by Aruba Central Guest. Consider it 'fair use' and included in the Guest Application subscription.
    Herman
  • 3.  RE: Aruba central sms
    Posted Dec 22, 2017 05:45 AM
     Herman,
    May i check with regards to the defination of fair use?
  • 4.  RE: Aruba central sms
    Posted Dec 22, 2017 07:06 AM
    If you just use it to provide guest access, that is fair use. If you find a way to use the service to send bulk SMS, that is not fair use.
    If you start sending 100x the number of SMS compared to subscribers of similar size that are normal/heavy users, you may be contacted on what is going on. I can't even imagine how you would get in such a situation.
    I wouldn't bother too much to be honest.
