Aruba Central - Some IAPs are monitored but not subscribed
  • 1.  Aruba Central - Some IAPs are monitored but not subscribed
    Posted Jul 19, 2018 08:24 AM
    Dears,
    I have deployed an IAP cluster linked to an Aruba Central account.
    I proceeded as following:
    - Local deployment of the first IAP and configuration of the virtual controller
    - Local deployment of other IAPs with manual configuration (hostname, IP, channel)
    - Creation of the Aruba Central account
    - Activation of the key
    - Link the Virtual controller to Aruba Central using Cloud Activation Key / MAC
    - I configured SSIDs and the configuration is correctly pushed on local virtual controller.
    I faced issues of virtual controller not able to synchronize with Aruba Activate anymore (resulting in a desynchronization with aruba Central..). I solved the issue by connecting locally in SSH, defining again the country code FR then reboot all AP and it solved the issue.
    I thought that it could be linked to a subscription issue and I discovered that even though all the 22 IAPs are active and managed by Aruba Central, there are only 15 IAPs (in reality 13 are currently active and 2 have been unprovisionned) of them that are recognized in Device Management.
    Here is a clearest view with screenshots:
    Aruba Central > Monitoring and Reports > Network Overview
    Aruba Central > Global Settings > Key Management
     Aruba Central > Global Settings > Device ManagementAruba Central - 15 devices including 2 down.png
    As Aruba Central is correctly monitoring UP IAPs, it should also assign a subscription to all of them, correct?
    Did I missed a fine detail?
    I think I will also need to unsuscribe the 2 unprovisionned devices but they are not present in Monitoring&Reports>Network Overview > APs to be able to Delete them from Aruba Central...
    Thanks in advance for your advices.
    Jérémy
