Hello all,
Within Aruba Central troubleshooting there is an option to run a speed test.
I can't make this feature work and it's not listed in the user guide. Can anyone detail how this should be configured. We will be using an iperf3 server.
This is actually an IAP feature, introduced in 6.5.4.
What you see on Central is only the UI portion allowing you to execute these commands through Central. You should be able to use the same parameters as on the IAP CLI, separated by a space: https://www.arubanetworks.com/techdocs/Instant_654_Webhelp/InstantWebHelp.htm#CLI_commands/speed-test.htm
Once you executed the command, it will show you the actual status of the speed-test. You can then also use the Troubleshooting commands to fetch the speed test results:
Any idea what these errors mean?
Result from Master APResult from Slave AP
I'm having the same issue with the main AP
Running FW 8.3.0.4_67604
Cluster with:
2 x AP-303-RW
6 x IAP-305-RW
Can you help?
Thank you
Still can't make this work.
Does anyone have a solution?
Thanks!
