Cloud Managed Networks
last person joined: 10 hours ago
Aruba Central supported APs
This thread has been viewed 57 times
  • 1.  Aruba Central supported APs
    Posted Feb 22, 2021 06:22 AM
    Hello Guys,
    We have a number of access points with model number AP-305. Just wanted to verify if they can work with  Aruba Central?
    GSM
  • 2.  RE: Aruba Central supported APs
    MVP EXPERT
    Posted Feb 22, 2021 06:45 AM
    If these are AP-305 as opposed to an IAP-305 then these will not work. They need to be of the 'IAP' variant. You can tell from the sticker on the back.
    *EDIT* Added Supported Device list.
    https://help.central.arubanetworks.com/2.5.2/documentation/online_help/content/access-points/supported-platforms/supported-aps.htm
    Craig Syme
  • 3.  RE: Aruba Central supported APs
    Posted Feb 22, 2021 07:22 AM
    @Craig - unfortunately these are mounted in the ceiling already. However they are also controlled by Aruba 7010. So, is there a way in GUI or CLI of 7010 controller to check the exact model APs that are connected to it, if it is an IAP-305 or just an AP-305?​
    GSM
  • 4.  RE: Aruba Central supported APs
    Posted Feb 23, 2021 09:05 AM
    I think if you have a Central account (can be evaluation), you can add one of your APs with the MAC + Serial number which you can get from the controller. The type (AP-305 or IAP-305) should then show up in the Central Registered Devices. As long as you don't link a subscription, there should not happen anything with the AP itself.
  • 5.  RE: Aruba Central supported APs
    Posted Feb 23, 2021 10:14 PM
    So I just bought an AP-335. Not an IAP-335. Will this device also not work with Aruba Central? What is the difference between the AP-335 and the IAP-335?
    eric frazer
  • 6.  RE: Aruba Central supported APs
    Posted Feb 24, 2021 04:17 AM
    The IAP-335 can run as Instant, Cloud Managed, Managed by a controller, or Remote AP.
    The AP-335 can run as Controller managed or Remote AP only, so always requires a controller.
    If you want to run that AP without management (Instant) or Cloud Managed, I would return the AP and get it replaced with an IAP. Both AP and IAP are priced the same on the Aruba Pricelist.
    I think the AP-335 is the last AP that had two different types, most current APs come as Unified AP which supports all the deployment modes.
  • 7.  RE: Aruba Central supported APs
    Posted May 03, 2021 10:10 PM
    You may convert them to IAP and work with central if your controller running ver 8.6 or later.  Please see link below.
    https://www.arubanetworks.com/techdocs/ArubaOS_86_Web_Help/Content/arubaos-solutions/access-points/conv-ap-iap.htm
    Asela Abhayapala
