Cloud Managed Networks
Aruba central two factor
This thread has been viewed 33 times
  • 1.  Aruba central two factor
    Posted Sep 20, 2021 07:27 AM
    Hi :)
    I see in the documentation that Google Auth and Authy is the two factor solution. In out company we use DUO integrated everywhere. I was able to set up using DUO but as a "Third Party" account, with using passcodes just like google auth. Is this the only possibility? Possible to set up using DUO push with our domain accounts?
    Thanks in advance for any advice
    Tore Valberg
  • 2.  RE: Aruba central two factor
    Posted Sep 20, 2021 08:14 AM
    You can configure Single Sign-On for Central (SAML Based). If your identity provider enforces the multi-factor, Central can leverage that. If you have integrated DUO with your Authentication (like AzureAD) already, it probably isn't that hard to set up.
  • 3.  RE: Aruba central two factor
    Posted Sep 20, 2021 07:50 PM
    yes it works in DUO.
    Downloaded DUO mobile app and scan the QR in Aruba Central then DUO will provide the 6 digit pin.
    Aruba Central supports generic 2FA Time-based One-time Password (TOTP) not only google authenticator
  • 4.  RE: Aruba central two factor
    Posted Sep 30, 2021 08:12 AM
    yeah that part work, but its a but tedious to use passcode when we have push in our domain set up. But hopefully it will work with proper push when we have SSO up and running.
    Tore Valberg
