Aruba Central + WebCC + ClearPass
  • 1.  Aruba Central + WebCC + ClearPass
    Posted Mar 29, 2017 02:51 PM
    Hi All, I'm looking to do a POC of Instant + Central for guest wireless. I I also want to use an existing ClearPass server that is being used for 802.1x for the Guest piece. Is all of this integration possible?
    IAP > Central (for web filtering) > ClearPass (Guest management)
    Also, I don't see where to configure web filtering in the Central demo site.
    N
  • 2.  RE: Aruba Central + WebCC + ClearPass
    Posted Mar 29, 2017 03:52 PM
    What do you mean about the Web filtering ?
    Are you trying to create a Captive Portal Profile that allows you to redirect a user to the ClearPass Guest Captive Portal ?
  • 3.  RE: Aruba Central + WebCC + ClearPass
    Posted Mar 31, 2017 12:20 PM
    No, I just want to block questionable content over wireless. Customer does not want to use on prem existing content filtering for some reason.
  • 4.  RE: Aruba Central + WebCC + ClearPass
    Posted Mar 31, 2017 12:23 PM
    You should able to create policies based on content within Aruba central.
    Get Outlook for iOS
