Aruba Central with CPPM
  • 1.  Aruba Central with CPPM
    Posted Sep 26, 2017 11:09 PM
    Hi ,
    I am new to Aruba , wondering if someone can answer these queries with explaination.
    1. Can i integrate CPPM with Aruba central? If my Aps are spread across the globe and CPPM is in Data center.
    2. In the same setup (Central with CPPM )can i use  AD,guest and on-board and on-guard services?
    3. If above is supported  and if i have 1000 Aruba central APs, how to i am going to add those as radius client in the CPPM server? Or i would need to create AP groups and make one of the AP as Virual controller.
    Could you please calify?
    Thanks in advance
    MD
  • 2.  RE: Aruba Central with CPPM
    Posted Sep 26, 2017 11:39 PM
    You won't necessarily will be integrating central with ClearPass but you can push the config to the IAPs from Central so that IAPs can communicate with ClearPass .
    If the IAPs are able to talk to your ClearPass server in your DC then you shouldn't have any issues.
    Same answer as the one above , the Aruba Instant will be the device interacting with ClearPass for (802.1X, Guest , Onboard) and the necessary configuration will be push from Central.
    What you can do is enable Dynamic RADIUS proxy (DRP) and that will allow you to use a single IP per IAP cluster as your RADIUS client in ClearPass
    http://community.arubanetworks.com/t5/Controller-less-WLANs/What-is-dynamic-radius-proxy-and-related-settings-in/ta-p/180918
