Aruba clearpass
  • 1.  Aruba clearpass
    Posted Sep 23, 2020 12:57 AM
    Hi Guys
    I'm welling to get an Aruba clearpass NAC for my network.
    my core switch is Aruba, and most of the Edge switches are Aruba Switches. the issue is that we have few Cisco Switches.
    will the Clearpass work with the Cisco Switches?
    and if it will work, will it work fine with no problems ?
    and thank you
  • 2.  RE: Aruba clearpass
    Posted Sep 23, 2020 03:58 AM
    There are quite some customers running ClearPass with Cisco switches and it works fine, some of them even exclusively on Cisco switches.
    In addition to that, Cisco wired switches are extensively described in the ClearPass Wired Enforcement Guide from https://arubanetworks.com/clearpassdocs, and Cisco wired and wireless is part of the ClearPass Expert Exam, which also shows the practical multi-vendor support.
  • 3.  RE: Aruba clearpass
    Posted Sep 23, 2020 06:35 AM
    thanks for responding man
